[湿度] 饱和盐水法做温湿度的湿度部分
cest01 发表于 2007-4-26 19:39:49 | 显示全部楼层 |阅读模式
呵呵
饱和盐水法做温湿度的湿度部分 对于那种数显的比较实用自己也可以做的
呵呵就是自己可以看看自己的湿度部分是否正确
等我把表格做好了就传上  大家给点意见
 楼主| cest01 发表于 2007-4-26 20:10:04 | 显示全部楼层
表格做好 错误请指出
温度物质LiClMgCl2K2CO3NaBrNaClKClKNO3K2SO4
533.643.163.575.787.796.696.6
1033.543.162.275.786.895.595.5
1512.233.343.260.775.685.994.494.4
15.533.343.260.675.685.894.394.3
1633.343.260.475.685.794.294.2
16.512.233.343.260.375.685.694.194.1
1712.133.243.260.175.685.59493.9
17.51233.243.26075.685.493.893.8
181233.243.259.875.685.393.793.6
18.51233.143.259.675.585.293.693.5
191233.143.259.575.585.293.493.4
19.51233.143.259.375.585.293.393.3
201233.143.259.175.585.193.293.2
20.511.933.143.258.975.58593.193.1
2111.93343.258.975.5859393
21.511.83343.258.675.484.992.992.8
2211.83343.258.575.484.892.792.7
22.511.732.943.258.375.484.792.692.6
2311.732.943.258.275.384.692.592.5
23.511.632.943.25875.484.592.492.4
2411.532.843.257.975.484.592.392.2
24.511.432.843.257.775.484.492.192.1
2511.332.843.257.675.384.39292
25.511.332.743.257.475.384.291.991.9
2611.332.743.257.375.184.291.791.7
26.511.332.743.257.175.284.191.591.5
2711.332.643.25775.28491.391.3
27.511.332.643.256.875.283.991.191.1
2811.332.543.256.775.183.990.990.9
28.511.332.543.256.575.183.890.790.7
2911.332.443.256.475.183.790.590.5
29.511.332.443.256.275.183.690.390.3
3011.332.443.25675.183.690.190.1
3511.332.143.254.674.98389.389.3
4011.231.643.253.274.782.387.987.9
参与人数 1金币 +3 收起 理由
上帝 + 3
jsntw 发表于 2007-4-27 10:55:29 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
Wangmn 发表于 2007-5-7 18:46:53 | 显示全部楼层
回复 #2 cest01 的帖子
以前也做过,好像数据不稳定.
ycjlzxj 发表于 2007-5-7 19:01:59 | 显示全部楼层
能给个附件吗?看起来特费劲!!
 楼主| cest01 发表于 2007-5-8 22:51:27 | 显示全部楼层
就是费时间一个东西要做一天一夜  还有就是干燥器(容器)不要太大  太大的话不容易到达稳定
易拉罐子 发表于 2007-5-10 18:07:54 | 显示全部楼层
饱和盐法不行的
饱和盐法做表面上是可行的,但是实际上由于校验时温度和干燥条件的要求很高,而且恒定时间很慢,操作起来累死人还不得好,产生的数据重复性很差。:(
GMT+8, 2025-11-3 21:57
